2 Errors when Loading SAP BW target!
Hi!
I have 2 issues:
Issue 1: Environment : Env1
I have a DI job that is loading data into SAP BW. Now in Dev, it seems to be running fine, but when I move it a different environment (Quality, pre-prod, etc.) I am getting an error “Target transfer structure schema size has changed. Please re-import transfer structure”. I have tried re-importing, re-migrating the code, re-building the job in that env (I know- poor me)… but I still cannot get this error to go away.
Is this some kind of set-up/config issue? I wasn’t facing this issue previously. It just came up one fine day! :flush:
Issue 2: Environment : Env2
The other error I am facing is some kind of Loader error for one particular SAP-BI table load. I can load all other tables perfectly but this table just wonr load!! DI is trying to hit BI after 1000 records(1 packet) and that is when the job fails due to this loader error.
PLEASE HELP!! :nonod:
PS : The above two issues are in 2 different environments.
MiaRamani (BOB member since 2009-12-02)
Please send me an email, I’d like to see things live.
Could you please give me your Email ID. I am unable to view ur profile… :frowning:
Doesn’t it show at the bottom of each of my posts? The three buttons?
