Is there someone using 0FI_GL_14 extractor by any chance?
ganeshxp (BOB member since 2008-07-17)
I had tested it, yes.
Werner Daehn (BOB member since 2004-12-17)
So where do you get the Delta Marker? In the BWOM2_TIMEST table?
EDIT:
Okay, I figured out the DELTA Table to myself. It is the ROOSGENDLM table. But here my problem is, how will I get an entry in this Table for the ECQ system? I got this auto-populated in the Config client and the basic DEV client. However it isnโt populate for the QA client. Do you have an insight to this?
