Hello members.
I’m loading data from a table to xml . i have created xsd with 16 columns and mapped them to xsd schema and given an xml file name to generate in specific folder. when i ran the job xml file is gerating fine but there two colmns are not coming into xml.
i have tried the job in debugging mode and observed that the data for two columns is coming fine but those are not coming in xml file generation.
and the two columns in xsd type is max35
I have tried connected resulted query o/p to templete xml , it is working fine and getting the data properly but when i see the actual xml file the data is coming for all the columns but not for two cols as mentioned above.
i’m banging my head to resolve this, i am not able to understand where am doing mistake.
Please suggest me and give me ur comments.
murali353 (BOB member since 2011-08-11)
