Dave wrote:
Our users are trying to develop reports in offline mode and then
connect back to the network at a later time to run the query.
They correctly check the box when logging in, however when trying to create
a report or edit an existing report the message
‘A connection required is not available’. Business Objects
is loaded locally. I thought you should be able to create or edit
existing queries in offline mode not connected to the network.
Offline mode does not mean “physically disconnected,” like it did in BO3.
Offline simply means that the SECURITY domain is offline, not the UNIVERSE
or DOCUMENT domains. So BO must still check the universe connection, even
in offline mode. That’s why you’re getting these error messages, I believe.
