Can anyone explain what is body operator and block operator in webi? and the difference between body and block.
mgs28
mgs28 (BOB member since 2012-01-04)
mgs28
In Block sets the context for each block or section whereas In Body is the standard default context for each row of data.
Raghvendra Deshpande (BOB member since 2008-05-26)
A Block in a report tab may be a Table or Chart or Section etc & Body means the whole report tab(Tables, Charts, Heading…everything in the report tab) of a Webi Document.
If you use any operator for a Block, it will be applied to a Block. Ex: If you Context Operators with “In Block” in the formula, it will be involving data in the Block only or if you use a report filter on a Block, it will work for that block only.
If you use any operator for the whole report, it will work for the whole report.
Hope thats enough for you to get started.
M H Mohammed (BOB member since 2010-06-16)
