WEBI running BO created documents
Does BO need to be installed on the same machine as WEBI? Is that why I am
getting the
“Internal error Unable to launch server process (returned by function
Import Report)” message when I do a “Refresh”? Documents created in WEBI
work fine, by the way.
Thanks in advance!
Dave
Dave,
Just before I read this message, I posted a similar one. If our problem is
indeed the same, your problem probably only occurs when wanting to show
BO-documents where calculations on the resultset have been made. Simple
reports work well.
It is indeed necessary to install BO on the webi-server and it seems that
only the version which is delivered on the webi-cd will do the job. We
still didn’t make it to work so any comments are welcome.
Hope this helps,
Diederik Dellaert
PricewaterhouseCoopers
Belgium
Dave writes:
Does BO need to be installed on the same machine as WEBI? Is that >why I am
getting the
Import Report)” message when I do a “Refresh”? Documents >created in WEBI
