Hi, we are on BI 4.2 SP6 Patch 5 and using the launch pad via Microsoft Edge Version 110.0.1587.41.
We have just noticed that certain functionality within Webi HTML does not seem to be working properly. For example, when I try and do ‘Format Table - Layout - Relation Position’ I just get a spinning wheel. If I try and open a document that has ‘Refresh on Open’ I just get the progress bar but after 30 minutes (for a document that should refresh in 2 seconds) the data has not been displayed. I get the same issue if you pressing the ‘Refresh All’ button, but going into the query panel and pressing ‘Run Query’ returns the results. Has anyone else experienced this? Is there an incompatibility with latest version of Microsoft Edge? Thanks
