We have a test environment with a single domain(only one bomain.key file on server in the nodes/locadata) in our repository,for BO61b+IIS+Win2k with SP4
2 tier Bo works just fine…we are able to publish & retrieve
However in 3tier mode, we get the following errors on Infoview
While trying to view a report in HTML/PDF/Bo
A system error occurred. (Error: INF 00130) (65535)
While trying to make a WebI report via the Java panel
Universe not found WIS00501
Internal error on call to ‘retrieveDataSource’ API WIS 30270
Internal error on call to ‘updateQuery’ API WIS 30270
BO is not running as a service; but is started by an account with a local Administartor account that has been enabled with
“Act as part of operating system” "logon as service " etc priviledges.
I have tried the resolutions given on the BO website, but nothing has changed. At this point it seems more like an access issue rather than an install issue to me - but I’ll appreciate direction about where to look for a solution
I have had this problem every time I have done the configuration with and domain id that has beed added to the local admin group. It has only worked for me when I used a local id.
Don’t know if this applies but we had the same error messages and it turned out that Webi was missing a fonts folder that was not installed. Copying the missing folder from another server solved the problem. We found this by running a trace on the server. I posted about this last month I think.
Scott
I checked the fonts folder - it contains a folder called ‘afm’ with 14.ps files
and 3 .xml files.
So I think it’s not he source of the problem - but I’ll check for the same strucutre in our previous server.
Thanks for ponting that out though
~Rohit
Well one further point is that the errors being displayed may have nothing to do with the real problem - the missing fonts folder in my case - and you don’t know this till you do a trace.
Post 1,000 on Bob - wow, and what a great way to learn by participating here.
CAUSE****
An internal error occured while calling the ‘answerPrompts’ API. (Error: WIS 30270) (Error: INF)" is a consequence of (CS) :DBDriver failed to load : /bobject/Enterprise6/dataAccess/RDBMS/connectionServer/libdbd_oci9.so (ld.so.1: /bobject/Enterprise6/bin/WIReportServer: fatal: libclntsh.so.9.0: open failed: No such file or directory)
We need to figure out why this connectionServer exception is occurring with the libclntsh.so.9.0 library.
all error 30270 that´s it.
****RESOLUTION
Run the command: ls -la /bobject/Enterprise6/dataAccess/RDBMS/connectionServer/libdbd_oci9.so when the problem is occurring.
Create a link from the Oracle 9 libraries to the Oracle 8 libraries in Enterprise 6.1b folder.
I am getting the same problem.I tried running the commanc that you mentioned but it says illegal command or parameter.
following is the error that i get when i try to refresh my full client reports in infoview.
“”“Exception: CS, DBDriver failed to load : /local/apps/app01/bobj651/dataAccess/RDBMS/connectionServer/libdbd_oci8.so (ld.so.1: /local/apps/app01/bobj651/bin/ConnectionServer: fatal: libclntsh.so.8.0: open failed: No such file or directory)”"""
BTW how do you connect oracle 8 and 9 libraries??
I have oracle 8.0, sun one server(Unix).
BTW
Please help.
Suddenly (no particular modification made on server), all sybase based reports (.rep) go wrong with
BusObj error BOL #109 Les fournisseurs de données suivants n’ont pas été correctement rafraîchis : Requête 1 avec GEN_CF3P. (DMA0007) (ARTAXERXES)
(renvoyé par la fonction Refreshing Document) )
when activating logs, found in boligh[…].log the followings lines
2005/12/06 14:28:49.900|>>|E| | 6929| 7| |||||||||||||||_SQLNet::CreateConnectionObject :CS, DBDriver failed to load : /bo_web/Webi651/dataAccess/RDBMS/connectionServer/libdbd_ctlib.so (ld.so.1: bolight: fatal: libct_r.so: open failed: No such file or directory)
2005/12/06 14:28:49.900|>>|E| | 6929| 7| |||||||||||||||SetErrorMsgException: CS, DBDriver failed to load : /bo_web/Webi651/dataAccess/RDBMS/connectionServer/libdbd_ctlib.so (ld.so.1: bolight: fatal: libct_r.so: open failed: No such file or directory)
We are getting API Error whenever any report runs for more than 5-6 mins through Infoview. We have connection open throughout the session (connection parameter).
Can any here please let me know how to avoid this error??? PLZZZZZZZZz
There has to some Server parameters like query-time-out or session-timeout or something like that which can be increased through which we can control API error in WEBI Admin Console.
Wts the main reason behind API error? We have feeling that whenever report runs for more than 5-6 mins we get API error.
Awaiting desperate help …
API Error: ProcessDPCommpands
We are using BO6.5 with Oracle 9i.
WEBI Server: SUN Box on UNIX
We are also using WebLogic Server
Hi!
I have the same error with one instalation in Solaris with Oracle 64 bits.
I install the 32bits driver and the 64 bits Oracle driver(its necesary for Data Services).
My problem its than i want create a new report gives me the error “dbdriver failed to load” this the “…oci11.so” and “…oci09.so”
I see the rights and everything its ok abd i dont know what can i do!
Some ideas?
Thanks!!!
Edit: Its with BO XI 3.1 but i think that its the same problem that in before post.
