Hi We are trying to consume WEBI generated SOAP WSDL from SSIS. We are able to connect and retrieve the WSDL and generate the XML file. The XML file is as shown below. But it is missing the column names and datatypes are being represented as column names. How can I overcome this.
<?xml version="1.0" encoding="utf-16"?>
<ArrayOfArrayOfAnyType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<ArrayOfAnyType>
<anyType xsi:type="xsd:double">2150291</anyType>
<anyType xsi:type="xsd:string">SPED</anyType>
<anyType xsi:type="xsd:double">3</anyType>
</ArrayOfAnyType>
<ArrayOfAnyType>
<anyType xsi:type="xsd:double">2508589</anyType>
<anyType xsi:type="xsd:string">MSGENERALIST</anyType>
</ArrayOfAnyType>
<ArrayOfAnyType>
<anyType xsi:type="xsd:double">2520912</anyType>
<anyType xsi:type="xsd:string">ELEMENTARY</anyType>
</ArrayOfAnyType>
<ArrayOfAnyType>
<anyType xsi:type="xsd:double">2554521</anyType>
<anyType xsi:type="xsd:string">HSMATH</anyType>
</ArrayOfAnyType>
</ArrayOfArrayOfAnyType>
I am new to the SSIS, ETL world been more on the Univ and report development side. Any guidance is much appreciated.
[Moderator Edit: Added code formatting - Andreas]
monty4u (BOB member since 2006-12-12)
