've simplified this script by about and I’m still getting the same problems. When I try to refresh this document in webi it comes up with the following error :
Automation exception BusinessObjects server process raised an Automation exception (BOMGR0060) IDispatch error #109 A variable prevented the data provider SQL 1 with <oracle 8.15 database> from being refreshed. (DMA0008):
However, if I click on Refresh again it will work PERFECTLY FINE!!!
Here is the script that is embedded :
Sub main()
Dim firstvar, secondvar As String
firstvar = Format(firstvar, “mm/dd/yyyy hh:mm:ss”) secondvar = Format(secondvar, “mm/dd/yyyy hh:mm:ss”)
Application.Variables.Item(“1) Please enter a Start Date Added”).Value = “2/1/2000 00:00:00” Application.Variables.Item(“2) Please enter an End Date Added”).Value = “2/29/2000 23:59:59”
ActiveDocument.Refresh
Application.Variables.Item(“1) Please enter a Start Date Added”).Delete Application.Variables.Item(“2) Please enter an End Date Added”).Delete End Sub
If I run it locally with full client I never receive any error. BO 5.0.2 Webi 2.5.2 NT boxes all around. They submitted this error to be fixed in the next SP but I don’t have that luxury of waiting and was wondering if anyone had any good ideas.
Ian
