VBA Script Help
I have a situation where I’m filling in the prompts for the report. I have 2 dataproviders, 1 is the report itself and 2 is pulling the dates to use for the prompts of dataprovider 1. If I refresh the 2nd dataprovider BO asks me to fill in the prompts manually even though I’m supplying them. If I comment out the refresh of the 2nd dataprovider then it will run perfect…what’s the deal? Even if I substitute var1 and var2 for “04/01/2000” and “04/10/2000” it will still ask me to fill in the values if I try to .refresh the dataprovider and it doesn’t if I comment it out.
In a nutshell this is what I have :
ActiveDocument.DataProviders.Item(2).Refresh
var1 = data retrieved from dp2
var2 = data retrieved from dp2
var1 = Format(var1, “mm/dd/yyyy HH:mm:ss”) var2 = Format(var2, “mm/dd/yyyy HH:mm:ss”)
Application.Variables.Item(“1) Please enter a Start Ship Date”).Value = var1 Application.Variables.Item(“2) Please enter an End Ship Date”).Value = var2 ActiveDocument.DataProviders.Item(1).Refresh
Ian,
What is your 2nd data provider? Does it pull the dates from database?
Do you have @variable() or @prompt() in 2nd data provider? From what I have understood, it shouldn’t have any. It should only refer to the objects, which pull data from database.
Vasan
Ian.Humphries@POWERQUEST.COM on 04/17/2000 01:14:40 PM
******************************************************************************* Note: The information contained in this message may be privileged and confidential and protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you. Ernst & Young LLP
Both are SQL and the second dataprovider is simply pulling the first day of last week and the last day of the previous week.
Ian
Vasan
SQL of 2nd data provider shouldn’t have any @variable() or @prompt().
Can you send me the SQL of 2nd data provider…
Vasan
Ian.Humphries@POWERQUEST.COM on 04/17/2000 02:47:30 PM
Ian
Vasan
Here is the SQL of the second dataprovider…
select
to_date(trunc(sysdate-7) ,‘mm/dd/yyyy hh24:mi:ss’)-1 StartDate, to_date(trunc(sysdate) ,‘mm/dd/yyyy hh24:mi:ss’)-1/63000 EndDate from dual
var1 = StartDate(from SQL of dataprovider 2 above) var2 = EndDate(from SQL of dataprovider 2 above)
That’s funny. When you refresh 2nd data provider, it shouldn’t ask you for the dates. Only when you refresh 1st data provider it should ask.
Did you try to refresh only 2nd data provider, directly from BO?
Vasan
Ian.Humphries@POWERQUEST.COM on 04/17/2000 03:23:29 PM
select
Ian,
Instead of Application Variables, try with ActiveDocument Variables like this :
ActiveDocument.Variables.Item(“1) Please enter a Start Ship Date”).Value = var1
ActiveDocument.Variables.Item(“2) Please enter an End Ship Date”).Value = var2
Hope this helps.
JP
I don’t know where you put this code, but this might help: If you perform a refresh of a dataprovider in the “before refresh” event of a document all dataproviders are refreshed! Don’t ask me why, according to BO support it is that way and it will remain so.
Geert Janssens.
Hello,
I think I had the same problem, try using the following lines of code in the right places:
application.interactive = false
and
application.interactive = true
Bye,
Robert Duindam
Fortis
DISCLAIMER******** Deze e-mail is uitsluitend bestemd voor de geadresseerde(n). Verstrekking aan en gebruik door anderen is niet toegestaan. Fortis sluit iedere aansprakelijkheid uit die voortvloeit uit electronische verzending.
This e-mail is intended exclusively for the addressee(s), and may not be passed on to, or made available for use by any person other than the addressee(s).
Fortis rules out any and every liability resulting from any electronic transmission.
This report will never be interactive…ie it is only for DAS scheduling only. Where would I use em and why? heh Here’s the scriptin in its entirety.
Sub main()
Dim vars As Variables
Dim I, J As Integer
Dim var1, var2 As String
Dim thisdoc As Document
Dim docvars As DocumentVariable
Set thisdoc = Application.ActiveDocument
For I = 1 To thisdoc.DocumentVariables.Count
If UCase(thisdoc.DocumentVariables.Item(I).Name) Like “START*” Then
For J = 1 To 2
var1 = (thisdoc.DocumentVariables.Item(I).Values(BoAllValues)(1)) Next J
End If
Next I
If UCase(thisdoc.DocumentVariables.Item(I).Name) Like “END*” Then
For J = 1 To 2
var2 = (thisdoc.DocumentVariables.Item(I).Values(BoAllValues)(1)) Next J
End If
Next I
Application.Variables.Item(“1) Please enter a Start Ship Date”).Delete Application.Variables.Item(“2) Please enter an End Ship Date”).Delete
ActiveDocument.Refresh
End Sub
robert.duindam@NL.FORTIS.COM 04/18/00 02:57AM >>>
Hello,
and
Bye,
Robert Duindam
Fortis
My bad, we are using 5.02, BCA and VBA…we just upgraded from 4.x so I’m still catching up on my terms :slight_smile:
robert.duindam@NL.FORTIS.COM 04/18/00 09:29AM >>>
Hi Ian,
I’m sorry but I thought you were using BO 5.x, BCA and VBA. So my suggestion is not of any use to you!
Robert Duindam
Hi Ian,
Robert Duindam
From: Ian Humphries[SMTP:Ian.Humphries@POWERQUEST.COM]
Sent: 18-4-2000 3:23 PM
Sub main()
Dim I, J As Integer
For J = 1 To 2
var1 =
Next J
End If
Next I
For J = 1 To 2
var2 =
Next J
End If
Next I
End Sub
Hello,
right places:
and
Bye,
Robert Duindam
Fortis
Web archives (24 hrs. a day now!): listserv.aol.com/archives/busob-l.html
Ok,
then try using:
put the interactive code around the last activedocument.refresh (ie your last line of code):
Again, I’m not sure we have the same problem. It prevents de prompt dialogbox of coming up!
Gr.
Robert Duindam
From: Duindam, R. (Robert)[SMTP:robert.duindam@NL.FORTIS.COM]
Sent: 18-4-2000 4:29 PM
Hi Ian,
Robert Duindam
Sub main()
Dim I, J As Integer
For J = 1 To 2
var1 =
Next J
End If
Next I
For J = 1 To 2
var2 =
Next J
End If
Next I
Date”).Delete
var1
var2
End Sub
Hello,
right places:
and
Bye,
Robert Duindam
Fortis
