I am trying to fetch the maximum value of a particular object E.g. the most recent order date .
I tried using the subquery tool but I did not get good data.
I was wondering if anyone out there knew a way of doing this.
I had the same problem. I tried a lot working with correlated sub query but never could get around it. The solution i found is i created a view with ex: object, and max date for that object and then try to join with the view in my universe.
I don’t particularly recommend this method but our company does use it. We have an Oracle view set up which, in addition to selecting a certain subset of records, also selects by using the MAX(date) function in Oracle to get the most recent status record.
Roger Poole
rpoole@nswc.navy.mil
