How does one begin using the Business Objects Software development kit? Is there an interface for it, or is it code to use in other applications?
langgang (BOB member since 2004-01-05)
SDK is opening the object model so you can customize Business Objects.
SDK is mainly is a license together with documentation (and code samples) - there is no particular interface, for example you will program in WebI SDK using JSP or ASP and use whatever generic editor you would use for programming in JSP or ASP.
Andreas (BOB member since 2002-06-20)
