system
1
Anyone seen this before:
<< Reports in Corpdocs all have a semi-colon in front of the value in any prompt field. You have to remove them to get the report to run.>> ?
its an inconvenience, but it makes people nervous about the upgrade. And they keep walking in to my cube to tell me.
thanks,
brent
system
2
Brent,
Is this an adjustment to your *prm or *.sbo files?
Chris
system
3
I checked in these files, but I didn’t find anything that explained it…
It works ok on our test box, and I copied the sbo files over - still the same thing…
Ideas??
