upgrade from 5.1.8 to 6.1
I am new to BO , i need to ask the required steps to upgrade 5.1.8 full client to 6.1 full client , what are the important things ( how do i migrate repository ) and what will be the effect of upgrade on all the universes , reports and users that are already in 5.1.8.
I am using oracle 8 i and windows xp professional
amdel61 :us: (BOB member since 2004-07-14)
You should read the deployement_upgrading.pdf. It tells you exactly what you need to know.
  1. Make a copy of your v5 repository on another database instance
  2. Connect to this news repository using supervisor v6
  3. Make the upgrade of it
  4. Make the QA of each BO ressources (universes, reports, etc) and carefull to difference of calculation between the 5.1.8 and 6.1.x
Where I can download upgrade from 6.1a and 6.1b?
And where is the numbers I can teel mine Bo is a or b?
Now i’m using 61.0.0.16052…
Kirurgs (BOB member since 2004-07-13)
You can download 6.1b from www.techsupport.BusinessObjects.com (go to “Registered Support Contacts” - requires valid maintenance contract).
