universe structure not refreshing
Hi All…
I am trying to refresh the universe structure view–> refresh structure…
but I see a message saying the selected tables were not found…and all the tables are highlited in the universe structure… can any one tell me a way out…
thanks
-phani
phani (BOB member since 2003-11-24)
The way out – don’t save your universe for now?
Are the tables/views in the universe really in the database? If so, does the login you’re using with BusinessObjects (via the connection) have database “rights” to use those tables/views?
HI
Thanks for the reply
Iam not working with the repository… Iam designing the universe on a stand alone mode.
and I have already saved the universe. Iam retreiveing the tables from the database and the DB has tables in it.
-phani
I’m also facing the same issue. My problem started after the BO connection was changed to test database from development database. When i imported the universe i don’t see any columns, but i can view the table values and also i’m able to insert new tables(In this case i see the columns).
I tried refreshing the structure and it says that table not found. The integrity checks on joins,conditions and objects were fine.
Would appreciate any help.
PB
bunty71 (BOB member since 2004-05-28)
