I have more than trouble, EVEN BUTTONS WITH ARROW UP AND ARROW DOWN DON’T CHANGE DATES!
What’s GOING ON?
Heellp!
What’s GOING ON?
Heellp!
I think you have to double-click on the two digits before you can actually change them.
Oddly enough.
What’s GOING ON?
Heellp!
What BO Supervisor Version are using?
What did you select in How list?
Don’t forget that the up and down buttons are functional only when you select(Highlight) dd, mm or yy.
And try to remove any timeStamp you’ve entered before, and apply one after another.
Hope this helps
Hamid
