Is there an easy way of using ‘SYSDATE’ in a condition as the first parameter in a ‘between’ condition, and prompt for the second date parameter? For example … from today’s date to 10/25/02.
where
Test_Date >= sysdate
and Test_Date <= @Prompt(‘Enter to date’)
The above does the same as a “Between”
Minal
Hello all:
The easiest way to do this is to create an object in your universe called “Today’s Date”. Define the object using sysdate and hey presto, away you go.
Dave
Hello all:
