Synchronization in Web 6.5
Hi , I have been informed that there is some bug with synchronization in Webi 6.5 if the report has multiple dataproviders.
Could some one help me understand the difference between linking and synchronization and what exactly is the bug within Webi 6.5
And if the report is re-developed in ZABO , will it still have the problem.
I have reports where it has drill down functionality , will it work in 6.5 Webi.
Any kind of help/tip related to 6.5 release of Webi or Reporter limitations or fixes ?
jatinr (BOB member since 2004-05-27)
Full client (aka ZABO, aka Reporter) documents have the ability to have multiple data providers, and for those data providers to be linked together (synchronized). Prior to 6.5, WEBI documents could have only one data provider. Beginning with 6.5, WEBI documents can have multiple data providers, but they still cannot be linked. It’s an improvement, but it’s not much different than having two documents really.
Hi Dwayne , if I understand correctly , then linking and synchronization means same ,I was told that one can link the dataproviders in 6.5 ,but the dataproviders don’t get refreshed sequentially automatically and needs to be refreshed manually?
Can you please elobarate on the exact bug within 6.5.
Also any tips on Drill down functionality will help me.
Appreciate your quick response.
In this context, yes.
I recommend that you double-check that source, because it is not my understanding. Maybe others will chime in here as well.
It’s not a bug, it’s simply a feature not yet implemented.
