Sybase related question
I think I saw something about this recently, but I can’t navigate back to it.
I have a person using Designer that is working against the same Sybase database that I am. When she inserts a table, the table name contains the name of the database + owner (sbo)+ name of the table. On my workstation, it does not do this. What switch where controls this? it makes it difficult to coordinate.
Seasons Greetings.
Jay
Jay.
I just posted something I think was similar this week. Business Objects includes directories for each of the major database. Each of these directories contains a parameter file .prm. My problem was that SQL Server was requiring an owner and I found out that it was because the OWNER parameter in the .prm file was set to Y. Check syb49en.prm and look at the value of the OWNER parameter - you may have it set to N and the other developer may have it set to Y. I think the QUALIFIER parameter may be important for you - SQL Server doesn’t use it but Sybase may - and it may be what is requiring the database name.
I hope this helps.
Marian Cooney
HBO & Company
Malvern, PA
Look for OWNER parameter in .sbo file in / directory.
– Vasan
Seasons Greetings.
Jay
Web archives (9am-5pm ET only): listserv.aol.com/archives/busob-l.html
Got the message, corrected the problem and gone for the holidays. Thanks for the all who replied and Happy Holidays to all of you who toil with Business Objects!
Jay
