Strange WebI document editing behavior
Hi.
One of our users is experiencing a strange WebI behaviour. He creates a crosstab query, runs it (the data comes back fine), and goes back by clicking Edit. At this point all his objects have been moved, and some have disappeared. None of the other users have ever had a similar problem.
We are using WebI 2.5.1, Full Java applet.
Any comments are greatly appreciated.
Can YOU duplicate the behavior?
Have you checked his version of the Java VM, have you checked his refresh options, run scandisk, etc?
And are you running under IE or netscape…?
Just curious,
Brent
Hi.
Brent,
No, I can’t reproduce it. He is running IE. I am curious if it’s a bug with WebI and if you (any of you) have seen it before.
Just curious,
Brent
One more thought, olga… have you tried to refresh the applet? Eg, go into windows\downloaded programs and select the webi applet, right click, refresh?
Maybe his copy is damaged - I have seen odd behaviour from that…
Brent
and some have
We are using WebI 2.5.1, Full Java applet. <<
Oh, that’s a good idea - I’ll check.
Thanks Brent.
the applet?
__________________________________________________ Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com
