Date: Mon, 13 Sep 1999 18:40:14 +0200
| I am using several stored procedures for the reports. It |makes too slow
|to run the report. Is there anyother way to avoid using |stored procedures
|and improving the performance. Any of you using stored |procedures??? Does
|it make slow down the report??? Any suggestions would be |appreciated.
Hmmm… I’m just thinking of using stored procedure to improve the performance (now we use stored functions and that makes the report very slow, as every function call is, in fact, a subquery). As it is usual with Oracle, the correct answer is “It depends”… It depends on how your procedure is written, on what indexes you have, maybe also on something else.
Ryszard Mikke
