store procedure
This is a multi-part message in MIME format. --------------19EF2E7402FEA63828A6DA8D
Hi alls,
How to create report from store procedure or PL/SQL. on BO 4 TIA
Ken
Never heard of a vcf format (attached file = chumphos.vcf). What application type is this?
Russ Coble
Information Technology Analyst
John Deere Credit - Des Moines
Phone: (515) 267-3794
E-Mail: CobleRussell@JDCorp.deere.com
From: Chumpol Suathes [SMTP:chumphos@CEMENTHAI.CO.TH] Sent: Thursday, March 09, 2000 5:33 AM
Hi alls,
Ken
<< File: Card for Chumpol Suathes >>
Russell.
I think the question should have been
"Hi alls,
How DO I create report from store procedure or PL/SQL. on BO 4 TIA"
The VCF is an attachement with the senders email address etc.
you need to create a connection in the supervisor module if you need to use the stored procedure to create reports. Once the connection is created, then login to BO & select Stored Procedure as the data provider. In case you need to create a report using SQL, then you can add a connection to the database from the BO module itself when you select SQL as you data provider.
Rgds
Naveen
