SQL*Net and Oracle versions
Hello Listers–
This is probably buried in the archives somewhere, but I didn’t stumble upon it.
At present, we’re on Oracle 7.3.4, with SQLNet 2.3. The machine that the repository lives on will be at Oracle 7.3.4 for some time yet. However, our DBAs are starting to move to Oracle 8, and one of the first instances to move is one that we have a universe defined against. The question is – will users who access that universe (via the 7.3.4 BusObj repository) need Net 8? Can it coexist with 2.3 for their other universe connections? What are the issues here? Similarly, once the instance with the BusObj moves to Oracle 8, but other databases are still at 7.3.4, what versions of SQLNet will work?
Amy Miller
Amy A. Miller, Data Analyst
University of Pennsylvania ISC
Office of Data Administration
3401 Walnut, Suite 265C /6228
Philadelphia, PA 19104-6228
Phone: 215-898-2171 Fax:215-898-0386
Email: milleraa@isc.upenn.edu
We also moved our databases and repository to Oracle 8 recently, We were still able to connect via SQL*Net 2.3 from the desktops. You will need to update your repository information via Supervisor once you have converted to Oracle 8 and we found that we needed to export all the universes due to some PCs not picking up the changes. We plan to convert the desktops to Net8 as they cutover to B.O. 5.0.
Annette Wells
Business Intelligence Services
annette.wells@eds.com
Phone: (972) 604-6286
Fax: (972) 604-6051
Hello Listers–
Amy,
Net8 should do the job for both databases, but you need to run BO setup and remove SQL*Net 2.3 component, this should solve the problem
Hamid
