I have a report with 8 fields now I generate report then set 1st three fields as master then I want the remaining report to be sorted on basis of the 1st column (which is 4th when report was generated first three were set as master so 4th is now 1st in report ) so I go to slice & dice panel set sort on the 4th but it does not work then I add sort to all 1st 4 columns still my 4th column is in mess can any one suggest the reason & solution for the same
james
rockstart (BOB member since 2004-05-14)
