Sorting Issue
We built a report in BO 6.1a which has a month sort. When it is published to Infoview it is missing the sorts. Is this because of the tool. I dint have the problem in 5i
BOB User :us: (BOB member since 2003-06-03)
Is it possible that your browser is caching an earlier version of the report? Try clearing the cache and see if that helps.
61b
I downloaded the report from Production and published in dev the sorting is working fine but the values are shown as #IERR.
In 61b ZABO works fine including the sorting and there are no errors but when the same report published to Infoview the values are shown as #IERR :confused:
61a
The same report that was built in 61b was downloaded on the machine that had 61a and published in dev it is unsorting the values but the #IERR is gone.
Did any one face similar issue with 61b.
I am kind of answering my issue may be useful for some one who may run into this.
The hot fix 74 when installed on 6.1a fixed the sorting issue. I still see the formating issues with 6.1b
Thank you. :yesnod:
Both tidbits are good to know, thanks.
