If do not retrieve data is checked, the query should not pull any data. It shouldn’t even attempt to pull data. (That would defeat the purpose of that option)
Having this checked does not affect doc agent. Doc agent uses the refresh command which overrides this option.
Are you saying the do not retrieve data option did not work properly on your query? Or are you saying that you received partial results after running it in Doc Agent? If it’s the latter, you may need to check your max row and time restrictions.
Shelley
