Can anyone help me?
Any idea how / where BO would translate semicolons to commas, eg, in an IN clause?
If I pull a report down to BO from the webi tool, it comes down and runs with semicolons as the seperator - but, the same report will not work on the web.
Used to work under 2.1x, but under 2.51 it has stopped… works under my full client, and I think my sbo / prm files are in synch… I think the full client tool is a notch smarter, but I am hoping that I can lead webi away from the darq side - ideas welcome. Brent
Seems to me that the Data configuration files would handle this type of translation. I’m not sure which one it is specifically (*.pfm or *.sbo) these should be found under the BusinessObjects 5.0\Data Access 5.0 directory.
Hope this helps.
James F. Lafferty
AERA Energy LLC
Applications Specialist
Office: 661.665.5126
Pager: 661.665.7566
e-mail jflafferty@aeraenergy.com
Can anyone help me?
