Selecting Multiple Values
Jay Ide wrote:
When executing a query, the dialog box is displayed to enter values for each
prompted value. I see references to selecting multiple values. But is
there a select multiple entries from the list box displayed in response to
the ‘Values’ button?
This depends on the comparison operator in the query panel. If you use
the “equal to” where you may pick an operand from a
LOV, then you are only allowed to pick ONE value from the list.
If the comparison operator is, e.g. “in list” then you are allowed to
select multiple entries from the LOV, by pressing ctrl+selecting the
entry (standard windows selection technique).
Hope this helps
Walter
Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna, Austria
Tel. +43-1-8151456-12, Fax: +43-1-8151456-21
e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
