Scripting Problem
I created a simple script from within business objects 4.1.2
rem from recording
sub main
Application.ExchangeMode = RepositoryMode Application.Documents.Receive
Application.Documents.Open(“RBOGL031”)
Application.Documents.Item(“RBOGL031”).DataProviders.Item("#DP#1").Edit
Application.Documents.Item(“RBOGL031”).Save Application.Documents.Item(“RBOGL031”).Close end sub
When I run this from within the report editor I have no problem it runs fine. When I exit business objects and try to run it from my desktop, it opens Business objects, allows me to login and says it cannot find the file. Any suggestions?
Julie Moran
I tried the following and it still doesn’t work. I run it from reportscript editor and it’s fine. When I exit business objects and try to run the script from explorer it gets into bus obj. and says it can’t find the file. I even tried placing the script file in the userdocs directory and running from there. Any other suggestions?
Julie
sub main
rem
rem Procedure PO001E01
rem
Application.Documents.Open(“C:\Program
Files\BusinessObjects\UserDocs\RBOPO001”)
rem OpenData RBOPO001.ASC
Application.Documents.Item(“RBOPO001”).Activate Application.Documents.Item(“RBOPO001”).Refresh rem SetReportVersion 1
rem SetReportTypeMatrix
rem SetReportTypeTabular
Application.Documents.Item(“RBOPO001”).Print Application.Documents.Item(“RBOPO001”).Close Application.Documents.Item(“RBOPO001.ASC”).Close rem
Application.Exit
end sub
Julie,
I ran your script. It runs fine.
The command line options for running the script are the following:
Command line options for invoking BusinessObjects (BusObj.exe) are as follows.
busobj -user -pass -nologo -blind -once -vars textfile_name -script script_name
where
-user A user login is required.
-pass A user password is required.
-nologo Inhibits logo display on startup.
-blind Operates with no displays.
-once Startup is one-time only.
-vars Sets one or more user variable values. textfile_name is the name of a text file in the format:
variable1 = value
variable2 = value
-script Starts a script.
script_name is the name of the .spt file without the extension
So in MS DOS command line:
Change drectory to BusinessObjects directory and type the following
C:\Program Files\BusinessObjects>busobj.exe -script scriptname
Or on the windows run command line type the following:
“c:\program files\businessobjects\busobj.exe” -script scriptname
If in business objects (TOOLS\OPTION) the location of files and scripts are set properly you need not worry about the path for these.
I hope this does the trick.
Manoj
______________________________ Reply Separator _________________________________
Author: Julie Moran Julie.Moran@FOREMOSTFARMS.COM at Internet
Date: 08/20/1998 1:24 PM
Julie
