Simple WebI report fails with the following error message…
Could not save the document to the repository for the following reason: [repo_proxy 17] unable to find the info : unknown session (WIS 30567)
Restarted the connection server, still the same error message.
Wireportserver log files has a entry
Could not save the document to the repository for the following reason: [repo_proxy 17] unable to find the info : unknown session (WIS 30567)" PREFIX=“ERR”>
Environment : BOE XI 3.1 SP2
CMS : Oracle 10g
I’m having the same issue…and I’m also on 3.1 SP2. I just applied SP2 a couple days ago…I didn’t have the issue prior, but then it’s inconsistent so there is a slight chance it wasn’t revealed during my scheduling testing, but I don’t think so. Do you know for sure this was introduced with SP2 in your environment?
For me it’s not happening consistently…but about 50% of the time. I’m doing some testing as we speak to narrow it down. Are you connecting to FileStore using UNC path, or is the FileStore on the local server. I have a distributed environment. Two clustered servers, each with full installs. You?
So I expect you were having the issue before applying any fix-pack/SP2 of the FRS not able to delete objects in the FileStore?
System problem encountered: Failed to remove file \bos01\BOXI31SupportFileStore\FileStore\Output\a_058\150\017\1152570\ from the file system. Please check for permissions or sharing violations
I think it’s possible this issue might get resolved if we can get ahold of a script that will clean up all those files from before that should have been deleted from the file store. Once in a while I get an error saying failed to add an object to the filesstore because it was already there.
Operation failed: Could not save the file \bos01\BOXI31SupportFileStore\FileStore\Output\a_032\163\017\1155872\cdz142c5b25105c4512a.wid to the File Repository Server. File already exists.
Apparently there is a script out there…I’m trying to track it down. I think it’s only a chance the cleanup will fix our problem, but would be good to do regardless.
I’m experiencing exactly the same problem as you are with a clustered environment and a filestore connected with UNC path.
I had this kind of message before applying SP2 "System problem encountered: Failed to remove file\ServerName\Input\a_058\150 from the file system. Please check for permissions or sharing violations "
and this one after applying SP2 "Operation failed: Could not save the file \ServerName\Input\a_058\150~cdzkdhdkekdye.wid to the File Repository Server. File already exists. "
So I’m very interested in what the support has to say about it. I’m waiting to see if you post something before opening my own case.
Have you checked all your timeouts? The timeouts in tomcat are set to 20 min(?), and the timeouts in BO-XI are less than that. It’s possible that your reportserver session timed out, and your session / the filestore link is broken.
Thanks…which error did it fix for you…the ‘object already exists’ error, or the failed instance? I deleted and added the SIA on each of my cluster servers, and I was still getting the failed instance issue.
Thanks Vijay…I’ve tried this already, but it didn’t fix this issue. I would test some more since I think it’s likely it’s not actually fixed in your environment.
I tried the timeouts as well, but the problem is still there. I find the best way to repro it is to schedule the same report 6 or 7 times, for the same time…then ususally at least a couple of them fail.
I’ve noticed something unexpected in the command line of the servers in my cluster. Then -ns switch points to the other server in the cluster.
In our R2 clustered environment, the -ns switch would have been the local server (ie. SERVER1 in this example). Not sure if this is related to the problem or not.
Anyone know how to change the default command lines in 3.1?
We have two servers clustered in this environment. I observed that if the CMS and Webi server doing the scheduling job are on the same server then the schedule is running fine but not if one of it is on the other node.
