Saving Complex Filtered Reports
I am using VB to automate filtering reports via complex filters then saving them. The problem is when I use VB to save these reports the filtered changes are lost. Has anyone experienced this? My code is as follows.
Set boApp = CreateObject(“BusinessObjects.Application”) Set boDoc = boApp.Documents.Open(DocString)
boApp.Visible = True
boApp.Interactive = False
Set vFilter = boApp.Variables.Item(“paramFilter”)
vFilter.Value = mvarPool
boApp.ActiveReport.ForceCompute
boDoc.Save
Thanks in advance,
Thom Susko
boDoc.Save
Thanks in advance,
Thom Susko
    Try the following:
    Instead of doing force compute on active report, do refresh
    on boDoc object as follows:
                      boDoc.Refresh
    Or try,        boDoc.Reports.Item(1).ForceCompute
    -- Vasan
saving
boDoc.Save
Thanks in advance,
Thom Susko
