Running Sum
2 DP/2crosstabs. Using only year, month, measure. Need 3rd cosstab to calculate the percent for each month/year combination between the 2 crosstabs. I know it’s a context thing but after screwing with it for 4 + hours, I’m exhausted. Any help would be appreciated. I’ve tried: =RunningSum() In (year1,month1)/RunningSum() In (year2,month2)
korzel :us: (BOB member since 2004-01-20)
Are your data providers linked on year1, year2, and on month1, month2?
Yes they are
Did you try something along the lines of:
=Sum(RunningSum(<Revenue> In  Body ; <Country>) In  Body) In (<Year>, <Month>)
Assuming you have Year and Month across and Country down in your crosstab.
Year is at top. Month name is on left side. Measures in body. Does this info create better perspective?
I’m attempting to use the value from crosstab1 and divide it by the value in crosstab2 for the same month/year to derive a %. Each crosstab is RunningSum-based so my formula is RunningSum(measure1)/RunningSum(measure2) in simple terms.
I can take a look at the report, if you want to send it to me.
I’ll send a watered-down version of it…just the 3 crosstabs in question. Otherwise, it’s much too busy. Thanks
