We are in the process of migrating from Sybase System 10 servers/databases to Sybase System 11. Our repository resides on a Sybase System 10 server. We did the following:
Created the same-named database on a System 11 server Made a copy of the repository database
Loaded that copy into the System 11 database Ran a Safe Recovery to create a new BOMAIN.key (security domain only) to access the new server
Logged into SUPERVISOR, selected TOOLS/REPOSITORY and modified the connections for the UNIVERSE and DOCUMENT domains with the new connection information.
This seemed to work ok. However, a major problem occurred when users tried to import reports from the new repository. The following error message was received:
UNABLE TO WRITE report-name. IMPORT CANCELLED. report-name CANNOT BE IMPORTED.
I was able to get around this by importing all reports from the “old” repository and then exporting them to the “new” repository. Once I did this, users could import reports. Since all repository tables were copied over to the new server, I thought that the re-export would not have to be done (since we did not re-create the Universe and Document domains but rather, copied them.)
Can anyone explain why I had to import and re-export all of the reports to the new repository?
2nd question: If another copy is made of the “old” repository (which is still in prodcution, the “new” repository is in test) and this copy is loaded onto the new server again, would I need to re-create the BOMAIN.key again or should the other one I created still work?
Thanks for any input.
