Repository Problem
Business Objects appears to behave strangely. Say I am using the userid “SCOTT” always. I generate a report and export it to the Repository. Then I change the report several times and export to the repository several times.
Fine till now.
Now I delete the report from the repository. And try to export the fresh copy of the same report from my machine. When I try to open the report, It says that I am not authorised to open the report.
I am using the userid SCOTT all the while. That’s Obviously strange …
Any workaround for this. Of course I had to generate the NEW report alltogether.
Thx in Advance.
g regards,
Aravind G
(TCS Consultant for GE Plastics),
Pittsfield,MA-01201, USA.
8*838 4711(work) or
413-448-4711(work)
g.aravind@gepex.ge.com
Go to supervisor module and do some research. Maybe you exported to different group.
What ever it is, General Supervisor will have global access. So open your report from GeneralSupervisor, select File/Save As. Check ‘Save for All Users’ in the save dialog box and click OK. This will remove any security info attached to report.
This way you won’t have to do it all again.
– Vasan
several times.
Fine till now.
Thx in Advance.
One easy way to resolve this is when ever you send a report to the Repository make sure before you send it you do a SaveAs and check the box marked
Save for all users. This does not work all of the time but it ensures consistant access most of the time. I’ve had alot of reports seem to be ‘corrupt’ or ‘unacessable’
from the repository and it is strange but this will work most of the time.
Debra
Aravind,
BusinessObjects is behaving properly; it is trying to prevent unauthorized access of files, regardless of whether you ever had access to the same.
Here’s an extract of the answer given by David Rathburn, Integra Solutions, to this question:
When you export the document to the repository, it gets assigned a unique document ID. This is to keep track of the information in the repository database. That ID is (apparently) stored in the document (on your hard drive)
as well. In other words, there is a little tag in the file that says, “I’ve been exported and therefore am now a secured document.”
When you open the document, BusObj detects that “tag” and says, “Hold on, I have to see if you are authorized to open this document.” A quick query against the repository information will let it know if the document is still valid, and b) if you still have permission to read it. (You would expect that
if you owned the document this would not be a problem.)
Fast forward: document has been deleted from the repository.
When you try to open the document, BusObj sees the same “exported tag” and tries to validate the security. Since the document no longer exists in the repository, the check fails! Therefore, you are not authorized to use this document. Strange as it may seem (since you have created the document to begin
with) you cannot open that document ever again. Nor can anyone else.
Except the General Supervisor. Nothing can ever be locked away from that user
(fortunately).
The General Supervisor ignores the security check, and therefore can open any
document. By opening with General Supervisor and using the “Save For All Users” option, you effectively remove the “tag” that says security should be checked on the document.
The bottom line is that you should do the “Save for all users” option before
deleting the document from the repository. That way you don’t have to bother the General Supervisor.
By the way, this same issue is possible when exporting universes. Once the universe has been exported, you should not delete it from the repository or the General Supervisor will once again have to ride to the rescue! *****
Luis Gonzalez
From: Aravind, G (GEP, Contractor) [SMTP:G.Aravind@GEPEX.GE.COM]
several times.
Fine till now.
Thx in Advance.
Fine till now.
Sorry to say this: this is what I expected from BusinessObjects. Whenever you export a report into the repository, this report becomes secured, i.e. only those users who are authorized may open the report from that point in time. This information is also saved in the .rep file. If you delete the report from the repository, nobody is authorized to open it again (except the creator(? not sure of that), or the supervisor). Otherwise, one might simply copy and distribute .rep files in order to override security. What you have to do its then: Save the report with “save as” and check the box “save for all users” BEFORE deleting it from the repository. This resets security information in the .rep file. Then you can delete the rep from repository and do whatever you want with your local copy.
Walter
Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna, Austria Tel. +43-1-8151456-12, Fax: +43-1-8151456-21 e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
Hi Michael,
U wrote:
Make sure that you have set up a connection to the repository database in Oracle
Net8 Assistant on your Webi machine. Without that connection, you won’t be able to log in to the repository.
In Net8 Assistant, double click on Service Names, then, in the menus at the top, go to Edit - Create. This will allow you to enter all the connection information for your database. You may need to recreate your BOMain.key after setting up the connection.
Michael Welter
Sr. Technical Analyst
Verizon Wireless
I opened Net8 Assistant but am not able to figure out how to set up a connection.The
database and webi are on the same server.I have also copied the BOMain.key file on
all the workstations as well as the server.Pls help.Thanks
Hi Michael,
I have a service name already created with the connection information for the db.If i try to login into Designer,Supervisor and BO from other workstations,it lets me login but only thro infoview it gives the problem.Pls comment.
Michael Welter
Verizon Wireless
______________________________________________________ 123India.com - India’s Premier Portal
Get your Free Email Account at http://www.123india.com
