Report refresh and distribution to private emails using BCA?
Hello,
I am kinda relatively new to this topic of Scheduling and sending reports to people using BCA. Is there a way that reports after refreshed (using BCA) can be sent to people (who use private emails) via email in a automated process.
Any help would be appreciated!
Thanks and Regards.
bo_reporter (BOB member since 2004-02-21)
You can either use the BCA Scheduler:
Add a VBA script in your document, which sends it per E-Mail.
Schedule a job in the BCA Scheduler, which uses that document and start the macro.
Or u can use the BCA Publisher, which allows u to distribute reports per E-Mail.
Problem: BCA Publisher needs an additional license, which is not cheap.
Bye.
cpoireault (BOB member since 2004-08-03)
Is this any use?
If you search around a bit, you should be able to find information on how other people have done this too. :slight_smile:
Paul Williams :uk: (BOB member since 2002-07-10)
This helps!
Thanks for the quick response.
Thanks and Regards!
