IROBOT ROOMBA S9+: THE SMART ROBOT VACUUM YOU’VE BEEN LOOKING FOR
When the Roomba wasn’t supposed to get any better, iRobot came and offered us the smart Roomba S9+ vacuum cleaner.
Compared with the previous i7+ of iRobot, this new generation is a better version with new design, more substantial suction power, and better navigation.
By taking things a step further with the Roomba s9+, our article today is going to give you a helpful review before you get one for your home.
Without further ado, let’s dive right into the heart of the matter!
âµâµâµ Picked For You: Good vacuum cleaner brands
What’s new with the Roomba S9+?
[list]
[:896058f724]Battery life: Up to 2 hours per cycle
[:896058f724]Charging time: 3-4 hours (for depleted battery)
[:896058f724]Level of noise: 65-68 dB
[:896058f724]Dimensions: 12.5’‘Ã3.5’’
[:896058f724]Weight: 8.15 lbs
[:896058f724]Warranty: 1 year
[/list]
As with a smart vacuum, the Roomba S9 can be controlled easily via Google Assistant or Alexa (using voice control) or the iHome App. All you need is a strong Wifi connection to has the vacuum work appropriately.
However, at 65-68 dB, the S9+ will be noisy, especially when performing on hardwood floors.
Suction Power
In comparison with the i7+, the new S9+ has more suction power.
Plus, with 2,500 Pa of suction power, the S9+ likely generates four times more power than the i7+ with 2,000 Pa. This makes it even perform better on carpets, especially the high-pile ones.
Design
The previous Roombas have a traditional round shape, whereas the S9+ comes with a D-shape design. Why is it so cool?
The S9+ can clean corners even better with the square-off front edge. Another bonus is a diffused exhaust to avoid dirt and debris being blown around.
Furthermore, the silicone brush rolls can even prevent dirt from getting tangled around itself.
Updated Cleaning Modes
Another impressive improvement of this Top best vacuum cleaners is the cleaning modes available.
Spot cleaning is modified. It no longer spins around in a dizzying circle, but around where the dirt is and eliminates it.
Flexible Navigation
The S9+ obviously maintains the same navigation as the previous i7+, yet it has been improved to be more productive.
Now you can set up the vacuum to clean each specific room, so it won’t come rolling into your baby’s room while they’re napping if you tell it not to.
It can memorize up to ten floor plans so that multi-level home cleaning won’t be a big deal.
What We Like:
[list]
[:896058f724]Increased suction power
[:896058f724]Better performance on corners
[:896058f724]Long-lasting battery life
[:896058f724]Smarter navigation
[:896058f724]Works well on carpets
[:896058f724]A good vacuum cleaner for busy homes
[/list]
What We Don’t Like:
[list]
[:896058f724]Too expensive
[:896058f724]Lack of a carry handle
[:896058f724]Not the right option for those who are unfamiliar with robot vacuums
[:896058f724]Too loud, especially when working and emptying
[:896058f724]Needs a strong Wifi connection
[:896058f724]The corner brush roll could be better
[/list]
â¡â¡â¡ See It Here: What is the best vacuum cleaner - Top rated vacuum cleaner reviews
Our Final Verdict
The iRobot Roomba S9+ is one of the best vacuum cleaners that we’ve found. That said, if you truly need a smart and powerful robot vacuum, the S9+ is the right one to get.
We hope that our article today can help you clear up those questions about this smart friend.
Thank you for reading.
hercules97 (BOB member since 2019-12-23)
