Repeated Section Headers
I have a report that I want to start a new page for each new section. I have some sections that are more than a page long, and I would like the master cell for those sections to report. Is there any way to do this?
timberjack :us: (BOB member since 2003-07-09)
Right-click somewhere in the blank area of a section and you will see your options
OR Menu bar … Format … Section
scott copeland (BOB member since 2002-08-15)
I really just create a Header with the cell information for the Section. Then I set my table to repeat the Header on each page. That should get you close to what you need.
-RM
You can also right click on the master cell and in the format cell properties, you can say repeat on every page.
Bharat :india: (BOB member since 2004-05-03)
