We are using REMEDY for call tracking at our help desk and it writes timestamps equal to the number of seconds that have passed since 1 Jan 1970. Is there someway to identify this date format to BO. I want to be able to schedule reports based on real dates (i.e. dd/mm/yyyy or FEB 1997) and not have to identify the total number of seconds since 1JAN70.
In a message dated 98-09-14 13:32:43 EDT, you write:
I would imagine that you will have to do this with logic in your objects. Since a date format to BusObj is expected to be a date value, you will need to translate your Remedy dates into some sort of standard dates.
What is your back-end database? There are various conversion functions available depending on what RDBMS vendor you are using.
You may also want to consider carefully how your query conditions are going to be written. If you have to use a conversion function, you would like to have the conversion done on the criteria rather than the database column (assuming indexes exist).
Jan
indexes exist).
