So I do not work with Lumira Designer very much. But I had a need to use it again. So here is the issue. I created a simple dashboard (one chart) and a cross tab and a timer. Within the timer I had it reload the data (reloadData) for my two data sources. The weird part, the chart disappears when data gets reloaded (tried a couple of different chart types) when executing the application (does not matter whether it is local on on the BI platform). The stranger part, I did not have this issue a few months ago.
Lumira Designer 23.0.0
kevlray
(BOB member since 2010-06-23)
