Relative Path
I am setting up a BOI to run on a network drive from a personal data file. I don’t want to have to make every person who uses the report map that drive to a particular letter. Is there a way to have the file name hold a relative path? I’ve tried a couple of things (with no success) and was hoping that maybe I’m just missing something…
Thanks in advance!!
Lisa
Lisa,
You should be able to use the drive’s UNC name. For example, instead of
P:\CorpData\test.txt
you could use
\FServer-SJ01\CorpData\test.txt
Cheers,
Luis Gonzalez
