Regarding WebI 6.1b drill option
I am new to WebI 6.1b version.
I need to create drilled reports on this version.
But there is no Drill option on my WebI 6.1b HTML Report Panel.
What is the reason?. Is there any installation issue or problem?.
Any one can help me on this regard
Thanks…
Madhu
Bandi Madhu :india: (BOB member since 2004-06-21)
You don’t see the magnifying glass for drilling at the top of your Webi report? Looks like it’s in the title bar.
scott copeland (BOB member since 2002-08-15)
Make sure the supervisor has granted you permission to drill.
Bandi,
Make sure the supevisor gave the permissions to you to drill down
check the tool bar options too
Tummala
Tummala (BOB member since 2003-12-04)
If the Universe is created on version 5.1.7.
Are there any hiccups to create reports on WebI 6.1b?
Any help would be appreciated.
Bandi
As far as I know, it did not give us any problems. We recently migrated from 5.1.7 to 6.1.B.
JSanthanam :india: (BOB member since 2003-12-17)
Bandi,
1 Make sure you migrated the universe (heirarchy set up) properly
2 check in your
WEBI -> OPTIONS -> VIEW -> WEB INTELLIGENCE DOCUMENTS -> DRILL OPTIONS -> (make sure hide drill down icon is unchecked)
3 check in the supervisor -> webi-> analysis -> work in drill down mode (enbled)
I think this will solve your problem
Tummala
