Regarding sorting
I need to show 12 month data for top 100 sales in a crosstab and i have 6 such crosstabs for different measures. I need to sort sales in desc order starting from current month. But when i sort the data, i dont get proper sorting order. I tried through query panel as well as through formatting. Any kinda help would be appreciated.
BOisBest :india: (BOB member since 2004-04-05)
Look for Custom Sorts:
Select your month column, go to Format| Sorts…, check the radio button labeled ā€œCustomā€, click on values, and arrange the sort order to your liking.
Andreas,
I have tried this option too. Month is getting sorted in desc order but the measure values for each month are not sorted properly.Any clues?
How about giving us a ā€œpictureā€ (that is, show us a sample crosstab) of what you’re getting, and another of what you want?
This is what i need :
                                     Month1    Month2   Month3
Code  Issue_Name             Sales      Sales      Sales ............
abcd   FinanceIssue         1200       1100       1250
efgh   Marketing              1100       1050       1100
So i need to sort sales in desc order starting from Month1. And this is what i’m getting:
xyz      HRDept                 1000        1100       1200
pqrs     Issuename            1200        1300       1250
These are not the actual figures but just to show you guys what i’m getting.
Looks like all you need to do is verify that there are no other sorts/breaks in your report and that you are sorting by CODE in Desc order. The Slice and Dice panel will make this visually apparent.
You may also want to verify what ā€œFormatā€ your Months are in. If they are returned as Dates, you will be fine, but if they are character you will need a custom format to ā€œfixā€ this.
I’m showing months as ā€˜Jan-03’. I’m getting proper order for months i.e.desc order.
digpen,
I have applied ranking on CODE based on sales to show top 100 records though. Is this hampering the sorting?
Yes! Ranking is essentially performing a ā€œsort and filterā€ function, and overrides any other settings.
Thanks Dyane
I 'm getting sorted results for one dimensions but when i try to restrict rows to top 100 through options in the Query panel, i get truncated results i.e. instead of getting 12 month data, i 'm getting data for a month only. Any clues?
The Query panel is restricting your return dataset to 100 rows of data. Unless you have some sorting occurring in the database, that 100 rows may be randomly selected based on the fetch sequence.
If you want the top 100 ranked, then you need to actually create a ranking object and then filter that. This can be done using a DRANK function in Oracle, though you may have to create the report in Freehand SQL if you want to control the context. I believe you will also need to rank in a sub-select so that you can restrict on it.
digpen,
when i try to use Oracle RANK function in my query, i get error message: object does not exist in the result.
