regarding infoview
i am having a problem in login to infoview homepage …
itz showing me an error USR 0003…(but the disable login is unchecked)
any idea of solving this :nonod:
thnx in advance
Ektha (BOB member since 2004-07-26)
Are you using version 2 or 6? Your question needs to be moved to the appropriate Webi forum. :wink:
What does this mean? Where are you seeing this “disable login” that is unchecked?
Can you give us a step by step of what your are doing, and exactly what is happening?
