Reg. FSCommand and Adobe Flex
Hi Experts
Can any one know how to use FSCommand in Crystal Xcelsius? IF knows please share with me. and I want to know about the adobe flex and how to create our own custom components.
Thanks in advance
Rajani
rajani_jagan :india: (BOB member since 2008-01-23)
Pass values from Xcelsius 2008 out to JavaScript:
FSCommand is a standard Flash call that Xcelsius 2008 makes available via
the FSCommand connection.
For more information on using FSCommand with JavaScript, see
http://www.moock.org/webdesign/flash/fscommand/index.html.
There are certain restrictions to Adobe Flash when you want to call out to
JavaScript; see the section “Flash Player Security” for more information
Source:https://www.sdn.sap.com/irj/sdn/go/portal/prtroot/docs/library/uuid/a084a11c-6564-2b10-79ac-cc1eb3f017ac
I have a working example. Please send your email id,because the file more than 250KB(it is 450 KB size).
dandamudi :india: (BOB member since 2008-07-03)
Would you please send me a copy of teh example also?
My email is in my profile and should display below in the email button.
Thanks a lot for this. So much to learn…
Cricri (BOB member since 2009-02-11)
Please check your Email…
Hi Dandamudi
I read that but i am unable to pass the paramaters to java script. can you please send me the example file.
Rajani
This file is above 25o kb…
Please give me your email. I will send to you…
Hello Srinivas
We are having issues passing parameters from Xcelsisus to teh Javascript.
Please send your example to the following ID: reddyshv@yahoo.com
BOLearner (BOB member since 2005-01-20)
Hi Dandamudi
Sorry for late reply. my email is : vemularajani@gmail.com
Rajani
I have sent email…
Please check and let me know is it meet your requirement?
Hi dandamudi,
I am looking for a solution to passing variables to Javascript.
Can you please send your example to anthony.tan.83@gmail.com.
anttan (BOB member since 2007-10-23)
Guy,
Just want to ask you if any one of you got the script from Dandamudi,
If so please forward it to saran.pottem@gmail.com
sam4u :us: (BOB member since 2008-01-09)
