R=?iso-8859-1?Q?=E9f._:_Vertical_report_orientation?=
I have not tried this but if I am not wrong, you can create a small report with 3-4 objects in the way you want it and store it as a template. Then if you are creating a report from scratch, select the new template instead of default template.
If you a report already, apply the template. But my experience says that applying template is more tedious because you have to rework on formatting and headers and footers anyway.
Hope this helps you.
Ashwani Malhotra
Thank you to Christophe & Michele for your ideas. They work OK with a limited number of objects but will be too labor-intensive for reports
with
up to 100 objects.
