Query panel disabled View and Run Buttons
Interesting situation happened to a remote user of mine.
She has a report that already contained conditions and result objects. She tried to add an additional condition and when she did the VIEW and RUN buttons grayed out.
I checked the universe because I could recreate this problem and it dealt with the LOV not being exported with the universe. So I checked the export LOV with universe and refresh LOV options and exported the universe.
Now it works fine on my machine (even when using the user own id), but it still does not work on her machine. I made sure she re-imported the universe.
Any thoughts, I am stumped.
Mike Lavin
FleetBoston Financial
Mike,
Did you make sure that she imported the .lov with the universe? I believe it doesn’t come over automatically. You have to select to import it with the universe.
Michael Welter
Sr. Technical Analyst
AirTouch
Hi Mike
Regarding your Problem
I have the following inputs which might be useful
If the report is generated by some one else , then it needs to be saved with ‘save for all users’ option
which might allow your user at the remote site to run the report.
The reason you might be able to run the report is that you might be having
the privileges like supervisor, designer which might allow you to run the report.
Thanks and Regards
Heston
Michael_J_Lavin@fleet.com on 02/18/2000 03:56:31 PM
Please respond to BUSOB-L@listserv.aol.com
cc: (bcc: Heston S Pitta)
Mike Lavin
If this is still an open issue, you may want to check if her applet is damaged / reload it…
In windows explorer, find her applet, check the properties, and if damaged, you can either update it (again from a right click) or delete and reload…
I also found that reloading the microsoft / java vm helps in applet problems… from control panel, add / remove programs, pick internet explorer and add components… you can pick the microsoft vm and reload just that part… this has fixed a variety of odd problems.
Brent
Hi Mike
report.
Thanks and Regards
Heston
objects.
VIEW and
and it
checked
exported the
universe.
id), but
re-imported
the universe.
Mike Lavin
