prompt problem
I am facing a unique problem
In my report i want current month project costing which prompts for
month and year from the user
also in the same report i want current year project costing which only prompts for the year( because its yearly)
now the problem is current month project costing is over writing the year prompt( meaning i m getting both columns with the same value) because when i run the report it only asks for month and year for current month and uses same prompt for the year too, when i onlu run current year column prompt works fine.
plz help…
amdel61 :us: (BOB member since 2004-07-14)
amdel61,
Can you be little more clear. Like are u creating the prompts in universe or in thick client or webi.
Make a note that when u are creating prompt in universe and pulling both prompt in same dataprovider then, prompt with more restrictions becomes effective, which is what might be happening in your case.
Faas :us: (BOB member since 2004-02-24)
This sounds like your two ‘year’ prompts are combining, which happens when the ‘prompt text’ is the same.
If this is the case, try changing your promtps to something like:
  1. Current Month costing - Enter Month
  2. Current Month costing - Enter Year
  3. Current Year costing - Enter Year
This should ensure they are 3 distinct prompts/variables when you get them in your report.
Hope this helps…
philmorris :uk: (BOB member since 2002-11-12)
