Problem with conditions when creating a document. (webi 2.7)
When creating a new document and building a query/document the drop down list in the conditions part doesn’t work correctly in ‘Light Java’ mode.
This problem only occurs when the user chooses a condition value which has the same start as another value i.e. NCCAO and NCCA. If the user chooses NCCAO it selects NCCA. This also happens with NCUPL and NCUP, NCUP is selected when either NCUPL or NCUP is chosen.
The problem does not occur with ‘Full Java’ or ‘Active X’. but the user can’t use these options, they also are not allowed to write their own SQL which would allow them to edit the incorrect condition
Every other value in the list is chosen correctly.
Is this a known bug? is there a work around.
Thanks for any ideas
matdey (BOB member since 2004-07-15)
One of my user has experienced the very same problem. I could convince my user to type the value as a constant instead of choosing it from the LoV. However, it is just a workaround and not a solution.
Cheers
Urs
Urs Aeschbacher (BOB member since 2002-09-02)
Urs
Thanks for that…
Works a treat.
Mat
