actively (@Prompt / UserResponse) OR Broadcast Agent (Script with SetAppl icationValue / ApplicationValue) MIME-Version: 1.0
Hi folks,
I realise that it is a long subject, but it’s a long story as well. Thanks for your help.
A customer, here in Australia, has to designed reports flexible enough to be able to be refreshed manually (Refresh Normally) or through the Broadcast Agent (Refresh Script) but getting the prompted values from a script, so we don’t have to reschedule the report every single time to change the prompt values.
And we want to display the values passed to the report and display them in the report in a cell.
So mainly, the idea is to display the value for “ApplicationValue()” or “UserResponse()” so we are sure the value returned is always filled. It works perfectly ONLY if you are refreshing the report interactively with or without script.
In the following variable’s definition, the user can choose a Year before to refresh the report.
If(ApplicationValue(“Year”)=“”) Then (UserResponse(“Query 1 with BEACH” ,“Year”)) Else (ApplicationValue(“Year”)) So if the Year has been filled interactively by a user, then we’d like to use “UserResponse()” otherwise if the script fixed the value then we use “ApplicationValue()”
As soon as you try to send the report to Broadcast Agent with the script the values stay blank in the report we retrieve from Broadcast Agent.
We have found so far the function ApplicationValue only works for the individual BusinessObjects
session that you are working in at that time. To prove this, if we open a document we noticed that the “ApplicationValue()” is no longer set.
This means that when BroadCast Agent has finished creating the document and ends that session, the “ApplicationValue()” is no longer associated to that report. If the variables that were used in the script are invoked when opening the document, then we saw them displayed in our report. If we do this we can’t refresh the prompts manually and won’t be able to refresh the documents the way we are trying to do.
Is there any other function we should use to get the values in both cases ?
Pascal BRENNER
Pascal BRENNER - BusinessObjects Pre-Sales Consultant
“A superior sailor is one who uses his superior judgement to keep out of situations that require the use of his superior skills.”
Executive Computing - Sydney Office - 6 Ryde Road - Hunters Hill 2110 - Australia
Professional Mail : pbrenner@ecg.com.au Personal Mail : pbrenner@technologist.com
Phone : +612 9816 3433
Fax : +612 9816 3455
